查看: 1036|回復: 0
10月份OPTION 報導KATE COOL -機油冷卻器
發表於 2013-9-15 13:23 | 顯示全部樓層 |閱讀模式
本帖最後由 olivia 於 2013-9-15 13:35 編輯
OIL COOLER
OIL COOLER
OIL COOLER
OIL COOLER
如有需產品需求 凡請撥打以下電話:
07-783-2372
並請告之為86俱樂部之車友喔 ^^
KATE COOL 為TOYOTA FT-86 / SUBARU BRZ 所特別開發的專用型機油冷卻器套件,套件內含原廠對應鎖點位置免破壞鑽孔專用的油冷器本體固定支架,及強制進氣增加散熱效率FT-86/BRZ 專屬的鋁製集風罩
冷卻器選用英式14排油路本體,經長期嚴苛測試,此款尺寸適中,不易發生加裝機油冷卻器後機油壓力不足的現象
油管採用汽車機油專用的耐高溫,增快機油流速,維持油壓穩定的金屬編織橡膠複合材質製成,外層再以防火尼龍編織網包覆,更能提升油管耐用度及安全性。
Kate Cool is an oil cooler kit exclusively developed for the Toyota GT-86 and the Subaru BRZ that includes an original equipment manufacturer oil cooler mounting bracket with corresponding snap points exclusively designed for damage-resistant drill holes, as well as an induction forcing and heat dissipation increasing aluminum fan shroud that is especially customized for the FT-86 and the BRZ.
This oil cooler has a British 14-row oil circuit that has undergone long and strict testing. The cooler is medium in size and rarely results in any lack of oil pressure after the oil cooler is assembled.
The oil pipes are made from heat-resistant metal braided rubber composite materials that speed up the velocity of the oil and keep the oil pressure stable. The exterior is covered with a nylon braided net to enhance the durability and safety of oil pipes.
GMT+8, 2024-5-22 07:45 , Processed in 0.056077 second(s), 9 queries , File On.
